Service engine light
64,000 MILES
ALAN MORRISON
Light came on. no issues with performance. plugged in meter code reads small evaporated leak fuel. I changed gas cap, no change, but notice light goes out after five hundred miles. then back on after five hundred miles, repeating in five hundred miles cycles. Car rides beautifully. Before changing out parts is there a simple fix?
Dec 5, 2017 at 9:13 AM
CARADIODOC
  • 34,413 POSTS
Small leaks can be almost impossible to find visually. To handle this problem, they make a smoke machine that you can use to inject a white, non-toxic smoke under two pounds of pressure, then you watch for where it sneaks out. You might be able to find one of these at an auto parts store that rents or borrows tools. Good suspects are loose or missing hose clamps around the gas tank and charcoal canister, and a leaking purge valve for that canister.
Dec 5, 2017 at 10:47 AM
