Check engine light
200,000 MILES • RWD • AUTOMATIC
LOVEMOODYBLUES
Check engine light came on about 3weeks ago car running sluggish... If I speed up real fast the check engine light will blink on and off...
Feb 11, 2017 at 6:28 AM
CARADIODOC
  • 34,414 POSTS
Hold on! A flashing Check Engine light indicates the most serious of conditions and you are supposed to stop the engine as quickly as is safely possible. The last thing you want to do is keep driving.
The flashing light means too much unburned fuel is going into the exhaust system where it will burn in the catalytic converter and overheat it. That damage can turn a minor problem into a very expensive one very quickly. The first thing to do is have the diagnostic fault codes read and recorded. The people at many auto parts stores will do that for you for free. The codes will indicate the circuit or system that needs further diagnosis, or the unacceptable operating condition.
Feb 11, 2017 at 6:34 AM
