Service anti theft system?
176,741 MILES • 3.6L • 4WD • AUTOMATIC
DOTSON4912
For 2 days, the truck will say service anti theft system, and will not crank at all, all lights and everything works but it will not crank, I changed the engine a month ago and it's ran perfect ever since, I also had to get a key made by a local locksmith and he programmed everything, the truck has ran fine since all of this up until 2 days ago, I pulled in to AutoZone, added a quart of the recommended transmission fluid to the pan plug, without spilling any, and got in the truck and it done it the first time, I should add that the 2 days it has done this, I have locked and unlocked the truck repeatedly multiple times and it seems to start randomly when doing that but now I'm stuck at a gas station and it won't work at all, I left the truck sitting overnight here and it still doesn't work, someone please help before I pull my hair out lol
Oct 17, 2026 at 4:57 PM
  • 55,748 POSTS
Adding transmission fluid would not trigger the immobilizer. Is the security light flashing? If not the security system is not enabled. Lets go overt these videos to help us get started fixing the problem. So when you say it will not start do you mean it will not crank over? or it cranks over but will not run?
https://www.youtube.com/watch?v=lXLJbuAZ4CE
Let run the codes to see which ones are stored.
https://www.youtube.com/watch?v=LBCpCWEFnTg
Let me know
Oct 18, 2026 at 8:31 AM
DOTSON4912
Security light isn't flashing, just stays solid, sometimes the red light on the bubble for the windshield blinks, no it will not even try to crank, battery showing perfect voltage, I've checked all grounds, all fuses.
Oct 18, 2026 at 10:39 AM
  • 55,748 POSTS
Okay, so the security system is not engaged, here Do you have power at the trigger wire for the starter? Please go over the second video in the post above.
Oct 18, 2026 at 12:20 PM
DOTSON4912
No I don't have power at the trigger wire, the truck is showing service theft detergent system also
Oct 18, 2026 at 12:22 PM
DOTSON4912
I have a barometric pressure high voltage code, a lin bus 1 lost communication with device code(been on the truck since I bought it years ago) and that's all
Oct 18, 2026 at 8:31 PM
  • 55,748 POSTS
Okay, lets do a CAN scan to see what codes are stored. Please go over this video.
https://www.youtube.com/watch?v=InIlnsjOVFA
Let me know, also here is the wiring diagrams for the starting circuit so you can see how the system works.
Oct 19, 2026 at 8:26 AM
