Service 4-wheel drive warning light turns on?
193,300 MILES • 5.3L • V8 • 4WD • AUTOMATIC
SCOTT-YUKON
Upon starting the display says service 4-wheel drive system.
Aug 29, 2022 at 8:10 AM
  • 55,746 POSTS
This light comes on when there is a problem in the traction control system, we need to run the codes with a CAN scanner, which is easy to do. You can get a CAN scanner from Amazon for about $30.00.
Here is a video to show you how:
https://youtu.be/u-4syLc-ifQ
Here is a scanner link:
https://amzn.to/3o41KcZ
It will probably be one of the front bearing hubs, here is how you will replace it:
https://youtu.be/ZgiPRG6jffc
Please let me know which code it is so I can help you fix it.
Aug 30, 2022 at 2:57 AM
