I had someone put on a serpentine belt for me on my car it is the GXP model. In the process they released tension from the tension-er instead of from the adjustment screw. After the application of the belt, they attempted to put the bolt back in the tension-er and broke the top of the spring that connects to the bracket. I recently purchased a serpentine belt tension-er from a 2007 GXP 5.3L. So my question is, will the 2007 tension-er fit my car and if not would I be able to tighten the belt manually?
Nov 30, 2017 at 8:05 AM
