I had a smooth drive home on my vehicle listed above 2.5t and i rev up the car on park only for the car to shut off and all the lights on dash boards came on, it gave a whining roll and won’t start back on, stepped out to check, found out the serpentine belt cut and got shredded. I changed the serpentine belt but still the car won’t start, keeping giving a whining sound. Everything connected on the serpentine belt turns also the timing belt rolls. I am not sure what the issue might be. Check the compression electrically its reading 120-160, the fuel supply is good.
Jun 10, 2024 at 11:28 PM
