Serpentine belt routing diagram without A/C needed
236,003 MILES • 3.0L • 6 CYL • 2WD • AUTOMATIC
THEO WATSON
I have the vehicle listed above without A/C and need the belt pattern. Please help.
Jun 12, 2022 at 12:46 AM
SQM
  • 6,383 POSTS
Please note that this vehicle had factory A/C for all models. So, the diagram that is available is with A/C.
However, if your vehicle is missing the A/C compressor, you can simply run the belt from the power steering pulley to the crankshaft pulley (as long it does not interfere with any other component. If you have the A/C compressor and you just want to bypass it, then you will have to make sure when you route the belt it does not touch the A/C pulley.
https://www.2carpros.com/articles/replace-serpentine-belt
I have attached diagrams below for your reference.
Jun 12, 2022 at 6:45 AM
