Serpentine belt installation issue
120 MILES • 3.5L • 6 CYL • 4WD • AUTOMATIC
MIKAMIKA
I put on the serpentine on correctly, but I don't know what I'm doing wrong to tighten it. I have the right tools. I just don't know what I'm doing wrong.
Apr 4, 2020 at 2:56 PM
  • 110,251 POSTS
I attached two pics. The first you can see the routing diagram, and the second is a very vague pic showing how to release the tensioner. The directions are very straight forward. Here they are:
__________________
2004 Acura Truck MDX V6-3471cc 3.5L
Procedures
Vehicle Engine, Cooling and Exhaust Engine Drive Belts, Mounts, Brackets and Accessories Drive Belt Service and Repair Procedures
PROCEDURES
Drive Belt Replacement
see pic 2
1. Move the auto-tensioner (A) to relieve tension from the drive belt (B), then remove the drive belt.
2. Install the new belt in the reverse order of removal.
____________________________
Does that help in any way? If not, explain what is happening for you
Apr 4, 2020 at 3:26 PM
