My serpentine belt came off, i bought new and replaced, the new belt was loose. so, i replaced the belt tensioner, but the belt is still loose.
Mar 3, 2024 at 2:29 AM
✓Experienced Mechanic
I believe there are two belts on this vehicle. If it is the one that drives the alternator and A/C compressor, are you sure the parts store gave you the correct belt? They may have given you one that is longer. Also, is it routed properly?
I attached a pic below showing the routing. Take a look and let me know.
