Serpentine belt riding toward the motor?
370,000 MILES • 5.2L • V8 • 4WD • AUTOMATIC
WENDY TILLEY
I changed the water pump now my belt is riding toward the motor on the A/C pulley. Could the idler pulley be bad?
Feb 1, 2025 at 7:34 PM
  • 55,588 POSTS
Yep, this is what happens when the belt tensioner needs to be replaced. Here is how the job is done. Check out the images (below). Please let us know what happens.
Feb 2, 2025 at 2:43 AM
WENDY TILLEY
So replacing the idler pulley should be a fix?
Feb 2, 2025 at 4:06 AM
  • 55,588 POSTS
It should but I would check to make sure the belt is installed correctly, (see if all of the ribs are on correctly).
Feb 3, 2025 at 12:07 AM
