Serpentine Belt
2000 VOLKSWAGEN GOLF
270,000 MILES • 2.0L • 4 CYL • 2WD • MANUAL
ESTHERANDERE48
I just replaced my serpentine belt on my car and the second I turned it on the one of the sides teared off. Just like the last one? What is causing my belt to split on one of the treads?
Apr 12, 2016 at 9:15 AM
HMAC300
  • CAR REPAIR CONTRIBUTOR
  • 48,601 POSTS
there can be many things on this. any time a belt is replaced the tensioner should be as well. check alignment of pulleys as one may be off. you can use a straight edge.if there is junk in one of the pulleys that will cause it.
Apr 12, 2016 at 9:58 AM
