I changed out the tensioner pulley, but the belt still squeaks. What do I do next?
Sep 6, 2025 at 5:45 PM
✓Experienced Mechanic
Did you change the belt as well? If so the squeaking can be a pulley bearing, alternator or the water pump. I would remove the belt and spin the pulleys to if you can hear the one making the noise.
