Serpentine belt replacement instructions needed
200,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
DAVID SMITH6
Need to know how to replace the belt.
Dec 27, 2020 at 12:50 PM
  • 110,248 POSTS
There are two different 2.0L engine possibilities. One is a single overhead cam the other is a dual overhead cam. I will provide directions for both.
______________________________-
Single Overhead Cam
2000 Ford Focus L4-2.0L SOHC VIN P
2.0L SPI
Vehicle Engine, Cooling and Exhaust Engine Drive Belts, Mounts, Brackets and Accessories Drive Belt Service and Repair Procedures Drive Belt 2.0L SPI
2.0L SPI
Accessory Drive Belt - 2.0L SPI
Removal
1. Raise and support the vehicle.
2. Remove the accessory drive belt splash shield.
see pic 1
3. Lower the vehicle.
4. Remove the accessory drive belt.
- Using a 3/8 inch square drive breaker bar in the hole provided, rotate the tensioner clockwise.
pic 2
Installation
1. To install, reverse the removal procedure.
Note: Pic 3 shows belt routing with AC and pic 4 is without AC.
_______________________________________________
2.0L Z-tec
2.0L Zetec-E (Zetec)
Vehicle Engine, Cooling and Exhaust Engine Drive Belts, Mounts, Brackets and Accessories Drive Belt Service and Repair Procedures Drive Belt 2.0L Zetec-E (Zetec)
2.0L ZETEC-E (ZETEC)
Accessory Drive Belt - 2.0L Zetec-E (Zetec)
Removal
2. Remove the splash shield.
pic 5
3. Remove the accessory drive belt.
- Rotate the accessory drive belt tensioner clockwise.
- Remove the accessory drive belt.
pic 6
Installation
Pic 7 shows belt routing for the Z-tec
Here is a link that shows in general how one is replaced. I thought it may help guide you.
Dec 27, 2020 at 2:15 PM
