I want to bypass my AC compressor
216,000 MILES • 4.0L • 6 CYL • 2WD • AUTOMATIC
SMASHIT
So I am trying to bypass my AC compressor without a bypass pulley. I have a shorter belt do I have to take off the fan blade protector?
Apr 7, 2018 at 7:13 AM
You do not need to remove this if you are going to use a shorter belt.
However, more than likely you are going to have use an idler pulley which is what Jeep uses when you don't have A/C.
Based on the routing of the belt, you would not be able to get from the water pump over to the alternator without routing it up to where the A/C or idler pulley would be.
https://www.2carpros.com/articles/replace-serpentine-belt
Please run through this info below and let us know what questions you have.
Nov 18, 2021 at 7:30 AM
