serpentine belt shred
220,000 MILES • 3.8L • 6 CYL • 2WD • AUTOMATIC
FIXITMR
  • 9,989 POSTS
when i bought this van the belt was reduced to to two grooves ret was missing. i put new Dayco on worked fine for 1,000 miles or more. then i had a no spark issue an noticed inside edge of belt missing and it tangled around HB and cracked crank sensor. I replaced crankshaft position sensor and kept same belt and that was working for a few hundred miles until the other day, i let it idle for thirty minutes and it quit, went under hood and belt was all wrapped up on HB!
Sep 17, 2017 at 10:31 PM
MIKE H R
  • 3,094 POSTS
check the pulleys and make sure there is nothing stuck to them, then check for allignment. see if any pulleys are loose or if one has some bearing going bad. Sometime it is hard getting them just right in the groves.
Sep 18, 2017 at 5:08 AM
FIXITMR
  • 9,989 POSTS
yes, i think the china balancer that was installed before it started failing. seems rubber looks like separation did notice a small ticking nose more muffled than lifters lately.
Sep 18, 2017 at 8:39 AM
FIXITMR
  • 9,989 POSTS
i wonder how many years interchange? mine is series two i think.
Sep 18, 2017 at 8:41 AM
MIKE H R
  • 3,094 POSTS
Do not know about that, but would seem that there are a few around.
Sep 18, 2017 at 10:10 AM
