when i bought this van the belt was reduced to to two grooves ret was missing. i put new Dayco on worked fine for 1,000 miles or more. then i had a no spark issue an noticed inside edge of belt missing and it tangled around HB and cracked crank sensor. I replaced crankshaft position sensor and kept same belt and that was working for a few hundred miles until the other day, i let it idle for thirty minutes and it quit, went under hood and belt was all wrapped up on HB!
Sep 17, 2017 at 10:31 PM
