Can i bypass the air condtioner clutch and compressor in replacing serpentine belt because clutch and compressor are bad.
Nov 1, 2016 at 1:57 PM
HMAC300
✓Experienced Mechanic
that is something that has to be done at an auto parts store. if clutch will still freewheel no need to do that just disconnect compressor wire.
Nov 2, 2016 at 12:21 AM
LISA CROUCH
MEMBER
The clutch completely fell apart in my hand so it is not even on the vehicle. something keeps tearing the belt to shreds which basically just powers the alternator since the compressor pulley will not move at all.
Nov 3, 2016 at 3:19 AM
HMAC300
it may have been the compressor pulley, if you have to by pass it then it has to be done at auto parts, hunt and try style as the manufacturers have no listing for this. we see this all the time.
