The serpentine belt clacks against the front of the engine when it is idling in gear, but not when driving or in park.
Jul 31, 2017 at 6:43 AM
STEVE W.
✓Experienced Mechanic
If it is moving that much you have a bad tension-er assembly, bad belt or one of the accessories is faulty. It should not be that loose. Best to get it checked and determine the problem before it breaks or falls off.
