Where are the camshaft position sensor and crankshaft sensors located?
137,000 MILES • 3.9L • 6 CYL • 2WD • AUTOMATIC
DICK LITTLE
Need to know where the camshaft position sensor and crankshaft sensors are located on engine.
Nov 17, 2024 at 7:20 AM
  • 110,246 POSTS
The camshaft position sensor is located at the front of the engine, center, below the intake manifold. See pics 1 and 2 below.
The crankshaft position sensor is located at the rear of the engine close to the firewall. See pics 3 and 4.
Let me know if this helps or if you have questions.
joe
Nov 17, 2024 at 1:14 PM
DICK LITTLE
When I change these sensors do I need to use a scan tool to delete them off BCM?
Nov 18, 2024 at 8:10 AM
  • 110,246 POSTS
If you are referring to the diagnostic trouble codes, I would delete them to make sure they don't return. If you wait long enough, they could clear on their own, but it may take some time.
Nov 18, 2024 at 11:09 AM
