Engine power reduced coming on
67,000 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
DARROL WADE
  • 5 POSTS
I am getting engine power reduced coming on. I had it to the dealer and was told it was fuel tank pressure sensor. I put a new one in and still have same problem. Any suggestions?
Jan 4, 2019 at 5:46 AM
Good afternoon,
What was the exact code?
Reduced power is from either the TPS or pedal sensor malfunction.
The engine control module (ECM) is the control center for the throttle actuator control (TAC) system. The ECM determines the driver's intent based on input form the accelerator pedal position sensors, then calculates the appropriate throttle response based on the throttle position sensors. The ECM achieves throttle positioning by providing a pulse width modulated voltage to the throttle actuator motor. The throttle blade is spring loaded in both directions, and the default position is slightly open.
Modes Of Operation
Normal Mode
During the operation of the TAC system, several modes, or functions, are considered normal. The following modes may be entered during normal operations:
* Minimum pedal value-At key-up, the ECM updates the learned minimum pedal value.
* Minimum throttle position values-At key-up, the ECM updates the learned minimum throttle position value. In order to learn the minimum throttle position value, the throttle blade is moved to the Closed position.
* Ice break mode-If the throttle blade is not able to reach a predetermined minimum throttle position, the ice break mode is entered. During the ice break mode, the ECM commands the maximum pulse width several times to the throttle actuator motor in the closing direction.
* Battery saver mode-After a predetermined time without engine RPM, the ECM commands the battery saver mode. During the battery saver mode, the TAC module removes the voltage from the motor control circuits, which removes the current draw used to maintain the idle position and allows the throttle to return to the spring loaded default position.
Reduced Engine Power Mode
When the ECM detects a condition with the TAC system, the ECM may enter a reduced engine power mode. Reduced engine power may cause one or more of the following conditions:
* Acceleration limiting-The ECM will continue to use the accelerator pedal for throttle control, however, the vehicle acceleration is limited.
* Limited throttle mode-The ECM will continue to use the accelerator pedal for throttle control, however, the maximum throttle opening is limited.
* Throttle default mode-The ECM will turn OFF the throttle actuator motor, and the throttle will return to the spring loaded default position.
* Forced idle mode-The ECM will perform the following actions:
- Limit engine speed to idle positioning the throttle position, or by controlling the fuel and spark if the throttle is turned OFF.
- Ignore the accelerator pedal input.
* Engine shutdown mode-The ECM will disable fuel and de-energize the throttle actuator.
Jan 4, 2019 at 6:00 AM
DARROL WADE
  • 5 POSTS
Thanks here are the codes that were checked: checked DTCs; P0561, P0532, P0455, P0107, P0106, P2270, P0141, P0054, P0036 set in ECM. Vehicle going into reduced engine power at times. Suspect fuel tank pressure sensor shorting out taking down 5 volts reference circuit 1.This is what the printout said. I am wondering could it be the MAP sensor?
Jan 4, 2019 at 9:48 AM
Yep, lots of 5 volt reference issues.
Pull the TPS connector and check for a 5 volt reference signal with the key on. wondering if the PCM is the issue as it sends the voltage from there.
Example 532
P0532
Descriptor
Probable Causes
5-Volt Reference Circuit Open or High Resistance
5-Volt Reference Circuit Short to Ground
A/C Refrigerant Pressure (ACP) Sensor
A/C Refrigerant Pressure (ACP) Sensor Signal Circuit Short to Ground
A/C Refrigerant Pressure (ACP) Sensor Signal Circuit Short to Voltage
Engine Control Module (ECM)
Low Reference Circuit Open or High Resistance
Jan 4, 2019 at 10:00 AM
DARROL WADE
  • 5 POSTS
Is the PCM the computer?
Jan 4, 2019 at 10:30 AM
Correct.
Jan 4, 2019 at 10:45 AM
DARROL WADE
  • 5 POSTS
How much to replace?
Jan 4, 2019 at 10:47 AM
If that is the problem, the computer is about $200.00. I posted the part below.
https://www.rockauto.com/en/catalog/chevrolet,2009,cobalt,2.2l+l4,1442864,electrical,engine+control+module+(ecm+computer),2896
The labor is one hour or about $100.00.
The flash programming is around $150.00.
You need to have this verified first. make sure there is no wire harness issue or you may damage the new module after installed.
Jan 4, 2019 at 7:21 PM
DARROL WADE
  • 5 POSTS
Thanks Roy.
Jan 4, 2019 at 11:00 PM
You are welcome.
Always glad to help.
Jan 4, 2019 at 11:18 PM
AUSTIN ALLISON
Roy I have a 2007 Cobalt with 2.0 just put a new clutch in and drive it over to a alignment shop and now it won’t start. tried to pop start it and nothing. Now when I turn the key on it don’t turn over or anything. all I can hear is relays clicking and a light comes on the dash says engine power reduced.
Oct 16, 2019 at 2:43 AM
Good afternoon,
I would be glad to help you but you need to start a new question at the beginning.
Oct 16, 2019 at 3:54 AM
