I was wondering what the sensor is located in the bottom of the radiator and if any one has a part number thank you?
Jul 4, 2018 at 2:23 PM
STEVE W.
✓Experienced Mechanic
That is the coolant thermos-witch. Believe it carries a part number of B3C818840 or F2G818840 if the information is correct. The image is that number. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Image (Click to enlarge)
Jul 4, 2018 at 4:54 PM
GRISSLE
MEMBER
1 POST
where is the sending unit located for temp gauge
Jan 4, 2021 at 1:06 AM
(Merged)
Its on the left front of engine block Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
