Sensor identification
134,000 MILES • 1.5L • 4 CYL • TURBO • 2WD • AUTOMATIC
ADAM FELS
  • 5 POSTS
While replacing camshaft position sensor I appear to have knock something loose that appears to be a sensor with a clip connector. It sits to top of engine towards rear of car connected to a round metal piece.
Sep 24, 2019 at 11:08 AM
  • 110,248 POSTS
Welcome to 2CarPros.
That's a tough one without seeing it. Is it possible for you to upload a pic of the item in question? Also, let me know if it is a 1.5 turbo, the 2.0 turbo, or the 1.6 turbo.
Sep 24, 2019 at 11:57 AM
ADAM FELS
  • 5 POSTS
1.5L EcoBoost turbo.
Sep 25, 2019 at 1:18 AM
  • 110,248 POSTS
Welcome back:
The silver item is a High Pressure Fuel Pump. I circled it in your pic. Let me know if that is the part you are referring to and what is loose?
Sep 25, 2019 at 11:08 AM
ADAM FELS
  • 5 POSTS
Thank you. that's what I was finding with further research. Can the solenoid be replaced inside it or will whole thing need to be replaced? Code showed fuel volume regulator control circuit.
Sep 25, 2019 at 11:13 AM
  • 110,248 POSTS
Welcome back:
It comes as a unit. Here are the directions for replacement. The attached pics correlate with the directions.
__________________________________________________________
Change Vehicle Bookmarks Library Request Conversion Calculator Technician's Reference - Collision
fuel pressure regulator
32
Community 17 Create Quote
2014 Ford Fusion FWD L4-1.5L Turbo
High-Pressure Fuel Pump
Vehicle Powertrain Management Fuel Delivery and Air Induction Fuel Pump Service and Repair Removal and Replacement High-Pressure Fuel Pump
HIGH-PRESSURE FUEL PUMP
Materials
pic 1
Removal
NOTICE: Do not loosen any fittings or plugs on the high-pressure fuel pump.
1. Refer to: Fuel System Pressure Release See: Fuel Pressure Release > Procedures > Fuel System Pressure Release (310-00A Fuel System - General Information - 1.5L EcoBoost (118kW/160PS), General Procedures).
2. Refer to: Battery Disconnect and Connect See: Battery > Procedures > Battery Disconnect and Connect (414-01 Battery, Mounting and Cables, General Procedures).
3.
1. Refer to: Spring Lock Couplings See: Fuel Line Coupler > Procedures > Spring Lock Couplings (310-00A Fuel System - General Information - 1.5L EcoBoost (118kW/160PS), General Procedures).
pic 2
4. NOTICE: To release the fuel pressure in the high pressure fuel tube, wrap the high-pressure fuel pump flare nut with a shop towel to absorb any residual fuel pressure during the loosening of high-pressure fuel pump flare nut.
pic 3
5. NOTE: Alternately loosen the 2 high-pressure fuel pump bolts one complete revolution at a time.
pic 4
6.
pic 5
7. If any flat spots or scoring are found, especially in the indicated areas, then inspect the high-pressure fuel pump and the high-pressure fuel pump tappet drive lobe. Install new components as necessary.
pic 6
Installation
1. NOTE: The cam lobe for the high-pressure fuel pump must be at BDC (bottom dead center) for the high-pressure fuel pump installation.
pic 7
2. NOTICE: Only rotate the crankshaft Clockwise (CW) or damage to the engine may occur.
pic 8
3. Material : Motorcraft(R) SAE 5W-20 Premium Synthetic Blend Motor Oil (U.S.)/ XO-5W20-QSP (U.S.) (WSS-M2C945-A)
pic 9
4. Make sure that a new high-pressure fuel pump O-ring is installed.
pic 10
5. NOTE: Make sure that 2 new high-pressure fuel pump mounting bolts are installed.
1. Install the high-pressure fuel pump and loosely install the 2 high-pressure fuel pump bolts, alternately tighten each bolt 90° at a time in turn until the torque is achieved
Torque : 80 lb.in (9 Nm)
pic 11
6. NOTE: Only tighten the 2 high pressure fuel tube flare nuts finger tight at this stage.
NOTE: Make sure that a new high pressure fuel tube is installed.
NOTE: Calculate the correct torque wrench setting for the following torque using the Torque Wrench Adapter Formulas.
Torque :
Stage 1: 15 lb.ft (21 Nm)
Stage 2: Wait 5min
Stage 3: 15 lb.ft (21 Nm)
pic 12
7.
pic 13
8. Refer to: Battery Disconnect and Connect See: Battery > Procedures > Battery Disconnect and Connect (414-01 Battery, Mounting and Cables, General Procedures).
9. Refer to: Fuel System Pressure Release See: Fuel Pressure Release > Procedures > Fuel System Pressure Release (310-00A Fuel System - General Information - 1.5L EcoBoost (118kW/160PS), General Procedures).
Let me know if this helps.
Sep 25, 2019 at 11:20 AM
ADAM FELS
  • 5 POSTS
So eventhough the connector in pic 13 is what broke off the whole thing has to be replaced?
Sep 25, 2019 at 11:29 AM
  • 110,248 POSTS
Welcome back:
Is it the connector on the pump or the connector on the wiring harness? If it is on the pump, I can't see how it could be replaced or repaired. It's a molded part.
Sep 25, 2019 at 11:55 AM
ADAM FELS
  • 5 POSTS
Connector on the pump. Wiring harness with female part to left of pump is fine.
Sep 25, 2019 at 12:10 PM
  • 110,248 POSTS
Welcome back:
Since it is on the pump, I would replace the unit. I can't see how it can be fixed safely, or even fixed at all. You don't want the chance of an electrical short at the high pressure fuel pump.
If I'm misunderstanding you, let me know.
Sep 25, 2019 at 12:26 PM
