Sensor identification needed
124,000 MILES • 5.0L • V8 • 2WD • AUTOMATIC
CLAUDE CROUSE
There is a sensor located top left of oil filter what is it?
Jun 19, 2020 at 8:50 PM
Good morning,
It is the oil pressure sender unit.
Do you have an issue with the sensor?
Jun 19, 2020 at 9:05 PM
CLAUDE CROUSE
Yes, I see fluid running out and my engine overheats at times.
Jun 19, 2020 at 9:16 PM
I attached a picture for you to view.
You can get it at any parts store. Remove the connector and remove the sensor.
Jun 19, 2020 at 9:20 PM
CLAUDE CROUSE
The car sat for 4 years. what else can I look for?
Jun 19, 2020 at 9:21 PM
Wow, it will take a lot to bring it back.
You will need to change every fluid in the car.
You will need to replace the tires.
You will need to replace the battery.
You will need to change the fuel tank, pump, new fuel, flush all the lines, and possibly the injectors.
It will not be cheap to bring this back to life.
Are you willing to do all this?
Jun 19, 2020 at 9:32 PM
CLAUDE CROUSE
Already doing it belts, hoses and looking for anything liking is very difficult but it's a great year for Lincoln and is a great car.
Jun 19, 2020 at 10:11 PM
Good for you.
This was a nice car in its time.
Let me know if you have any other questions.
Jun 19, 2020 at 10:13 PM
