Bubbles like it overheating, gauge does not read hot
110,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
DAVIDRAP69
It bubbles like it overheating when it says on gauge not hot. runs rough at idle sometimes shuts off when trying to take off from light. code say it temperature sensor and vacuum leak.
May 9, 2019 at 1:13 AM
Hi David,
Just so we can get on the same page, what codes are you getting?
Also, are you saying the coolant is bubbling but the gauge does not say it is hot but you have a temperature sensor code?
May 9, 2019 at 9:07 AM
