where is the drivers side sensor ? and where is the control head? thanks, Dan Dailey
Jan 13, 2017 at 6:15 AM
CARADIODOC
✓Experienced Mechanic
There are dozens of sensors. Which one are you referring to and what problem are you trying to solve?
Jan 13, 2017 at 6:18 AM
CARADIODOC
You also need to specify the model of the car.
Jan 13, 2017 at 6:20 AM
DANIEL DAILEY
MEMBER
driver side temperature sensor. 1998 Buick, Park Avenue.
Jan 13, 2017 at 6:22 AM
CARADIODOC
The coolant temperature sensor is under the thermostat housing, left rear of the engine.
Intake air temperature sensor is in the fresh air tube leading to the throttle body assembly.
Here is a drawing from Mitchell ProDemand showing the other sensors.
