Part of the issue may be that I only show the engine option as a 3.5L. You said your engine is a 2.9L. Is this accurate?
I have included the location for the ECT sensor. If you look at the second screen shot, you will see I put a box around the ECT sensor. The line that appears you are referring too is most likely a bypass hose in the even the thermostat is stuck.
Can you get a picture a little further back and we will see if we can locate your sensor assuming this is the same engine. Thanks
Images (Click to enlarge)
May 3, 2020 at 2:39 AM
