On the back side of block above oil pan is a one wire sending unit. It is leaking oil. What is this unit called?
Jun 12, 2019 at 10:41 AM
DANNY L
✓Experienced Mechanic
Hello, I'm Danny.
That is the oil pressure sending unit.It is what relays the oil pressure readings to the oil gauge/light on your instrument panel.Hope this helps and thanks for using 2CarPros.
Danny-
Jun 12, 2019 at 10:47 AM
BPARRISH
MEMBER
Thanks for your reply. It is a one wire sending unit.
Jun 12, 2019 at 11:49 AM
DANNY L
You're welcome. Yes, It's a one wire sending unit.Thanks again for using 2CarPros.
Danny-
