self diagnosis for check engine light
274,000 MILES • 3.0L • 6 CYL • 2WD • AUTOMATIC
MOBILEOILGUY
when i try the self diagnosis the light does not flash. now what
Nov 4, 2014 at 4:20 AM
  • 110,251 POSTS
Is this an OBD2 system? The transition year was that year and I need to know what you have. Also, what is the problem? It may be something that didn't set a trouble code.
Nov 4, 2014 at 9:38 AM
MOBILEOILGUY
sorry. this a 1994 model.
Nov 4, 2014 at 9:28 PM
  • 110,251 POSTS
Okay... you may not have any codes stored. Can you explain what the vehicle is doing?
Nov 4, 2014 at 10:58 PM
MOBILEOILGUY
well i had a mechanic hook it up a couple of years ago and he told me i had a n oxygen sensor not heating up right but i can't remember which one. i want to sell car so i need to take care of this. thanks
Nov 4, 2014 at 11:10 PM
  • 110,251 POSTS
Okay, if the light is on and the vehicle runs properly, chances are it is an emissions related problem. I believe your vehicle only has one heated o2 sensor. If that was the code he found and it has never been replaced, I would just replace it now.
Nov 5, 2014 at 12:40 AM
MOBILEOILGUY
which one is heated?
Nov 5, 2014 at 12:59 AM
  • 110,251 POSTS
See attached pic. Sorry, there are actually 2 on the V6
Nov 5, 2014 at 9:57 AM
