Selector shaft seal replacement?
230,000 MILES • 4 CYL • 2WD • AUTOMATIC
COMARSH LUNAN
Leaking from the selector shaft seal, any help in going about it? Thanks in advance.
May 8, 2024 at 2:25 AM
STEVE W.
  • 15,420 POSTS
The book shows replacing them as part of an overhaul, however they are both installed from the exterior of the case. As such it should be possible to replace them without tearing the transmission apart. I would suggest doing it as part of a service, so you don't take a shower in transmission fluid. Drain the fluid and drop the pan.
Now to change the seal you unbolt the lever from the side. Then use some brake cleaner to clean off all the crud from around the seal. Then use a screw to pull the old seal out like these videos:
https://www.youtube.com/watch?v=iQwulUnPxew
https://www.youtube.com/watch?v=Ehqz1Y-ggGo
Then use a piece of tubing or pipe to install the new seal.
May 10, 2024 at 12:15 PM
COMARSH LUNAN
Thanks a lot. You mentioned “them” is it more than 1? It’s a 2000 Tacoma 2.7 pre runners sr5. Do you happen to know the part number?
May 11, 2024 at 11:25 AM
STEVE W.
  • 15,420 POSTS
The shaft goes through the transmission, so it has a seal on both sides of the transmission. However, if it's only leaking on the lever side you don't need to do both. They only list a full overhaul kit not the individual seals.
May 11, 2024 at 12:27 PM
COMARSH LUNAN
Do you have any information on the overhaul kit, so I can purchase it all in one?
May 13, 2024 at 4:06 AM
STEVE W.
  • 15,420 POSTS
The better kit is available through the dealer, for the aftermarket kits you need the numbers off the transaxle, so you get all the correct seals. There were a few minor changes made over the years. A dealer can give you the newest part number using your VIN number.
May 13, 2024 at 7:39 AM
COMARSH LUNAN
Thanks for all your help!!
May 14, 2024 at 2:23 AM
STEVE W.
  • 15,420 POSTS
You're welcome.
May 14, 2024 at 5:53 AM
COMARSH LUNAN
So, I purchased all that I needed from the dealer. No more leaks thanks to you once more. However, for some reason when I put it in reverse, I noticed that my backup camera is not coming on, nor the reverse light but it is running just fine no problem. When I am in reverse, and I barely pushed forward onto the gear leveler I notice the camera light comes on but not when it’s sitting directly in reverse. Any idea what I might’ve done accidentally?
May 22, 2024 at 11:09 AM
STEVE W.
  • 15,420 POSTS
Sounds like the shifter position switch isn't adjusted just right. Just loosen the bolt slightly. Put the truck in reverse and rotate the switch until it stops. Now put it into reverse with blocked wheels and slowly move the switch until you see the lights come on. make a mark on the switch showing where you stopped, now rotate a bit more until they go off. Mark. Now rotate the switch to be between those two marks. Test the shifter and be sure it is correct.
May 22, 2024 at 12:43 PM
COMARSH LUNAN
Will try this later. Thanks
May 23, 2024 at 12:02 AM
STEVE W.
  • 15,420 POSTS
No problem. I like to do it inside or at night so I can see the lights easier.
May 23, 2024 at 3:37 AM
