Seized ignition barrel
59,000 MILES • 1.1L • 4 CYL • 2WD • MANUAL
HED SPINNER
Key won't turn in the barrel so can't start the car and steering lock is on. any ideas on what fault might be? I have tried spraying WD-40 into lock but had no effect.
Nov 15, 2019 at 10:17 AM
  • 110,248 POSTS
Hi:
Have you tried a different key? I have seen the key wear out to a point it no longer will release the tumblers in the lock cylinder.
Take a look through this link. It provides ideas that may help. I realize you already have tried a lubricant, but there are additional options.
https://www.2carpros.com/articles/ignition-switch-wont-turn-stuck
Let me know if this helps.
Nov 15, 2019 at 2:27 PM
