Seized engine?
214,370 MILES • 4.7L • V8 • 4WD • AUTOMATIC
LENIN JOSE
My vehicle listed above the engine seized, tried to rotate by hand but it's not moving. i don't know what to do. If i get guidance to fix I will be very happy to try it. Can you help me to fix this? it was running without any problem before it got stuck.
Apr 22, 2025 at 11:21 AM
STEVE W.
  • 15,421 POSTS
What occurred just prior to the problem? From the description I would try removing the serpentine belt, then see if you can turn the crankshaft pulley by hand. If you can now rotate it, then go to each of the items the belt powers and see if one is locked up. If it still will not turn, then it's likely time for a replacement engine.
Apr 22, 2025 at 11:39 AM
