Seems to misfire and delay to throttle
160,000 MILES
LEATHOL
When I push the throttle down the engine seems to have a delay and seems to under rev and revs up really slow almost like a limiter is in place . Some internal backfire. Very small , idle changes.
Mar 3, 2020 at 11:21 PM
Good morning,
Several possibilities.
https://www.2carpros.com/articles/engine-has-low-power-output
1. Low fuel pressure.
2. Clogged cat converter.
https://www.2carpros.com/articles/bad-catalytic-converter-symptoms
3. Timing.
https://www.2carpros.com/articles/how-a-timing-belt-works
Any recent work? 160,000, did you have the timing belt changed?
Do you have any codes stored? If so, can you post them?
Mar 4, 2020 at 12:18 AM
