truck idles fine, revs up no problem but shuts off under acceleration like its out of gas. has more than three quarters of a tank. changed fuel pump three years ago. turned out to be a coil with weak spark. so i had an extra coil and tried it for the heck of it, still doing it. going to check the fuel pressure but weather is not being nice. there are a few more things i want to check like the TPS circuit and make sure i have all good power and grounds to everything. what gets me is the first time it happened it would not even start. That is why i tried the coil, who knows. A blind squirrel gets a nut once in a while! and of course no engine light or codes to check.
Apr 25, 2018 at 9:32 AM
