Seems like it is starving for gas
120,000 MILES • 2.2L • 4 CYL • 2WD • MANUAL
DYNADAVE
The truck set for 4 years I drained gas tank put new fuel pump, new filter, and plugs. it starts right up idles fine, but when you put it in gear it just bogs down. somebody told me it's ignition module. I'm stumped. please help!
Apr 12, 2020 at 12:29 AM
Good morning,
It sounds like you may still have some issues with the fuel.
The injectors may need to be replaced as all that old fuel was in them and they may be carboned up.
https://www.2carpros.com/articles/how-to-replace-a-fuel-injector
Apr 12, 2020 at 12:52 AM
This could be an ignition issue but due to it sitting so long I suspect you still have a fuel issue. Basically when you put the vehicle in gear it is adding a load to the engine and if the fuel is not sufficient it will bog down.
Sounds like you got the majority of the fuel system but we don't know what is in the injectors.
If it were me, I would at least attempt to clean the injectors out with the procedure attached and if they are okay, we can dig into the ignition system. I attached that info as well in case we need it.
Let me know what you find with this and we can go from there. Thanks
Apr 12, 2020 at 1:04 AM
DYNADAVE
Thank you so much for your help. you guys are awesome. I will check out every thing you have shown me. thank you again. I will be in touch.
Apr 12, 2020 at 11:09 AM
Sounds great. Let us know what you find and one of us will get back to you. Thanks
Apr 12, 2020 at 11:16 AM
