Seems like it's has no power
139,000 MILES
TONYD235
  • 62 POSTS
I changed the MASS AIR FLOW SENSOR METER because the car kept choking off and running rough. Once I did the car runs smooth. But when I try and drive it . It has no power. I press the gas to the floor and it still takes a while to catch up. What could be my problem? Thank you for your help!!
Jul 16, 2013 at 12:00 AM
WRENCHTECH
  • 20,760 POSTS
Check engine light coming on?
Read the fuel pressure and check for restricted exhaust.
Jul 16, 2013 at 1:13 AM
TONYD235
  • 62 POSTS
Thank you!! I checked the fuel pressure and it's fine. Do you have any other ideas? Now it seems that the transmission doesn't want to change. I smell burnt oil. But sitting idle the car runs great.
Jul 18, 2013 at 5:19 AM
