Big drop in fuel economy?
140,000 MILES • 5.0L • V8
MIKE BEDIER
My truck listed above Lariat was running fine. Then shut off while driving. The ignition switch went bad according to the mechanic and damaged the fuel sensor, the EFI sensor and blew the fusible link. I had all those replaced it runs but now only gets 10 mpg down from 15 mpg before I had it fixed. What would cause a dramatic drop in fuel economy? It has a miss I can feel as well. Thanks for your help
Dec 8, 2020 at 7:28 PM
  • 110,248 POSTS
If the fuel pressure is too high or low, it can cause a misfire and affect the fuel mileage. Do me a favor. This truck has an OBD1 computer system. You can retrieve codes without a scan tool. All you will need is a test light.
Here is a link that explains how it is done. Do this and let me know what codes are found.
https://www.2carpros.com/articles/ford-lincoln-mercury-obd1-1995-and-earlier-diagnostic-trouble-code-definition-and-retrieval
Dec 9, 2020 at 11:29 AM
