After removing positive battery terminal first by mistake car turns over won't start. Tried remove battery cable 10 minutes left key on removed anti theft fuse and nothing. Took both terminals off hooked jumper cable between the 2 hooked all back up and nothing. cranks good no start. Had check engine port tested mechanic say security system needs reset. 2 hours to nearest dealer anyway to not have it towed?
Mar 10, 2020 at 4:46 AM
