head lights fade, engine pops back, and shut off.
160,000 MILES • 3.1L • V6 • 2WD • AUTOMATIC
MAX2984
car ran then engine head lights fade engine pops back and shut off. Security system?
Sep 5, 2021 at 1:05 AM
Is there a reason that you are thinking this is a security issue? Is the light staying on or flashing?
I would suggest we start with checking for codes and see what is there.
Also, if this is a security issue then this guide will help with the basics to find out if we can just shut it off:
https://www.2carpros.com/articles/how-to-reset-a-security-system
If not then if the headlights faded, that sounds more like a battery or alternator issue.
So we need to get both of those tested as well. Here are guides that show how to load test both.
Lets start with all this and go from there. Thanks
Sep 5, 2021 at 1:10 AM
MAX2984
Thanks for the prompt response. i did change the alternator and battery the security lights comes on and then starts flashing engine turns over but doesn't start.
Sep 5, 2021 at 2:29 AM
Okay. if the theft system is on or flashing then that is preventing the start.
I assume you are using the remote to unlock it and it does not work? What about unlocking the door with the key? If that doesn't work then we may just have an issue with the door circuit so here is testing. However, I would start with checking for codes because if there is an issue with the system it should have a code.
Let us know what you find with this and we can go from there. Thanks
Sep 5, 2021 at 11:15 PM
