Security system
165,000 MILES • 4.0L • 6 CYL • 4WD • AUTOMATIC
TAMMY WITHROW
Last night anti-key popped on. Now it will run for five seconds​ then turn off. I already disconnected negative cable. I also changed the security fuse. And still have same problem. What more can I do?
Jun 28, 2017 at 1:19 AM
STEVE W.
  • 15,423 POSTS
That description fits the anti-theft module not being able to read the key. There are a few pieces that control that. Most are not DIY friendly because you need a scan tool to be able to "see" what the system is doing.
It is a fairly common problem but without the scan tool you could swap some costly parts and still not repair it.
Jun 28, 2017 at 1:48 AM
