Security reset?
189,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
JOHNMILLER
I lost keys to the truck. Replaced key cylinder. I have tried to do the ten- and thirty-minute resets several times, but the security light never goes off within ten minutes. Truck starts for just a few seconds. Won’t run. Is there anything else I could try?
Oct 27, 2022 at 12:57 AM
  • 55,647 POSTS
This happens when the security system has a functionality error. You can try a hard reboot which is done by removing the negative side of the battery, with the cable loose from the negative side of the battery, hold it to the positive terminal for 1 minute this will discharge the memory capacitors in the BCM and PCM allowing the system to reboot.
This guide can help as well:
https://www.2carpros.com/articles/how-to-reset-a-security-system
Please go over this guide and report back.
Oct 29, 2022 at 2:56 AM
