I need the security pin if available. We suspect the immobilizer is bad since the security light will flash even after the ten minute relearn. Battery voltage is fine. We are unable to program the transmitter also with the key on and opening door procedure. My friend is in Costa Rica and they can not service his car. Any suggestions to by pass so pcm will operate or kits to bypass? We can find an immobilizer unit. Thanks
Apr 12, 2017 at 3:21 AM
