Security Lockout?
AUTOMATIC
PCAVINEE
  • 31 POSTS
My grandson has this car and it appears the security lockout is the issue. I would like to know if I could reset the computer. I watched your guy Ryan today remove the negative battery cable and using aligatror clips and a wire he placed one clip on the positive and the other on the negative disconnect cable to drain all the current. He was working on a F-150.
I have tryed everything, the 30 minute procedure, jumping from the replay. The engine will crank but no fuel command.
Thanks for helping.
Oct 24, 2026 at 10:44 AM
STEVE W.
  • 15,421 POSTS
What does the security light do when you try to start it? Usually if it is the immobilizer it will activate and stay on if it isn't detecting the key, or more common is that it will start and run about 3 seconds and shut off because of the pump disable signal. If it isn't doing that then I would suspect a bad pump, They tend to fail abruptly, and for some reason they love to fail on a full tank of fuel just to make the repair more fun. If it isn't doing the start and shut off there is a quick test that may show a bad pump, that is to go under the car and hit the fuel tank HARD a few times, then see if it runs, if so it's a bad pump. If the security light is on what does it do with the key off but in the ignition, what does it do when you turn it on, and what does it do when you try to start it?
Oct 24, 2026 at 4:26 PM
PCAVINEE
  • 31 POSTS
Steve when I turn the switch to start, I hear a click in the ignition switch and it won't turn over. The only way if will turn over is jumping the relay but it just cranks, no start. Security lute comes on but does not stay on. I've checked fuses relays new starter.
Oct 24, 2026 at 6:11 PM
STEVE W.
  • 15,421 POSTS
OK, that description isn't the immobilizer. The light coming on and going out means it's reading the key. However it sounds like the signal from the ignition switch isn't making it to the starter relay. That signal also turns on power to the fuel system. Could you verify the vehicle for me. Year and engine please. That will allow me to find the correct wiring diagram so we can ID the correct parts. Thank you.
Oct 24, 2026 at 9:06 PM
PCAVINEE
  • 31 POSTS
2009 Monta Carlo
Oct 25, 2026 at 6:02 AM
STEVE W.
  • 15,421 POSTS
There is a minor detail, the Monte was discontinued in 2007, Maybe the VIN would clear it up.
Oct 25, 2026 at 9:51 AM
