Security lock out wait three minutes
100,000 MILES • V8 • 2WD • AUTOMATIC
LIZZARDMAN1269
Been going on for years about three, now I took it to my mechanic he did something inside the steering column to he amps he says there were only two wires, now I get it back and A/C compressor will not engage, worked perfect even he said, and no speedometer working? Any ideas?
Jul 29, 2017 at 1:07 AM
STEVE W.
  • 15,413 POSTS
Most of the issues with the security system on those is in the actual key switch assembly not reading the key correctly. Either because of the two wires breaking or the internal contacts that touch the chip in the key wearing out.
From the description it sounds like he moved the wiring harnesses under the dash around and you ended up with at least one of them failing. Without seeing it up close it could be as simple as taking the connectors apart, spraying them with cleaner and re-connecting. Or it could be that a wire broke inside one of them.
I would take it back and explain what is wrong. If the "mechanic" cannot get it working, take it to another shop.
Jul 29, 2017 at 1:17 AM
