BUZZSAW,
I HAVEN'T NOTICED IT OVERHEATING JUST LOOSING COOLANT AND RIGHT MUCH OF IT INFACT. I WILL PAY CLOSER ATTENTION TO THE TEMP HAND.
Your ign switch is bad for the theft sys, your not clear on the coolant leaks[/quote:78cf258824]
THANK YOU VERY MUCH FOR THAT INPUT BUZZSAW. I WILL DEFINITELY HAVE MY IGN CHECKED OUT. ALSO, AS FOR MY COOLANT, IT JUST KEEPS LEAKING AND IT SEEMS TO BE LEAKING FROM THE TOP/CAP ON THE RADIATOR AND HAS BEEN FOR ABOUT 6-8 MONTHS, BUT LIKE I SAID JUST DAYS AGO, IT STOPPED. HELP![/Quote:78cf258824]
is it overheating? You need to have it pressure tested, ck the water pump belt and tensioner its on the front head drivers side you have to take off a bracket its 1 10mm bolt, another ck; turn the AC on go to the front of the motor and a fan should be running up front[/quote:78cf258824]
Wednesday, April 16th, 2008 AT 11:55 AM
