Car will not start, security lock out
147,000 MILES • 5.7L • V8 • 2WD • AUTOMATIC
CHEVY GAL
I turn the key and get nothing, not the sound of clicking from the starter working. Security light is on.
Feb 3, 2019 at 5:55 PM
Good morning,
Did you try another key? It is possible it is the key.
https://www.2carpros.com/articles/how-to-reset-a-security-system
The body control module is what controls the security for allowing the car to start and the light to go off.
You can try turning on the car and let it sit for ten minutes and see if the security light goes out. If it does, turn it off and do it again. Try this three times and that should allow the BCM to learn the pass-code.
^ Resynchronization may be necessary due to the security method used by the remote keyless entry system.
The transmitter does not send the same signal twice to the body control module (BCM).
^ The BCM will not respond to a signal that has been sent previously.
This prevents anyone from recording and playing back the signal from the transmitter.
^ The panic button should still operate normally when the system is out of synchronization.
^ Resynchronization may be necessary under the following conditions:
- The battery in the transmitter is very weak.
- The battery in the transmitter was replaced.
- The battery in the vehicle has been in a low or no charge condition for an extended period of time.
^ In order to resynchronize the transmitter with the BCM, perform the following steps:
1. Stand within 1.5 meters (5 ft) from the vehicle.
2. Simultaneously press and hold the LOCK and UNLOCK buttons on the transmitter for 7 seconds.
The door locks should cycle and the park lamps should flash in order to confirm resynchronization.
Feb 3, 2019 at 6:03 PM
