Security light stays on
71,000 MILES • V8 • 2WD • AUTOMATIC
TFASH
Please, why would the security light on the instrument cluster remain on when I start the engine and throughout my drive time until I shut down the engine. This started after I recently change the fuel pump of the vehicle.
My mechanic said it will reset itself after some time when I complained, but I am worried about the indicator, although the vehicle drive superbly without any hitch.
Thanks
Nov 26, 2019 at 11:40 PM
94 TRANSAM
  • 680 POSTS
Sometimes when the battery is disconnected for a long period of time you need to reset the security.
Turn the key to run. Do not start it. Leave the key on for 10 mins until the security light either goes out or flashes. Turn the key off for 10 seconds then back to run.
Repeat this 3 times, total of 30 minutes. At the end of the third time, turn the key off and then start the car and the security light should be out.
This guide can help as well.
https://www.2carpros.com/articles/how-to-reset-a-security-system
Rich
Nov 27, 2019 at 9:16 AM
TFASH
Thanks Rich for the response. I will get back to you on this however it goes.
Nov 27, 2019 at 12:31 PM
94 TRANSAM
  • 680 POSTS
Perfect, thank you.
Rich
Nov 27, 2019 at 1:54 PM
