How to reset security
148,000 MILES • 4.0L • V6 • 2WD • AUTOMATIC
ROSS ODEN
How do you reset security after replacing lock cylinder and ignition?
Mar 11, 2020 at 10:26 AM
STEVE W.
  • 15,381 POSTS
Because you have changed the lock cylinder itself you need to use a dealer level scan tool to program in the replacement keys into the PATS hardware. The procedure that used the original keys to program a new key will not work as you need to be able to turn the ignition on and off with the key during the process and with a different key cut you cannot do that.
Mar 11, 2020 at 6:19 PM
BMDOUBLE
  • 1,139 POSTS
No programming is necessary if just the ignition lock cylinder is replaced, unless you are replacing it because you want a new set of keys due to theft, new owner, etc.
Mar 12, 2020 at 4:19 AM
