Will not start and flashing security light
135,000 MILES • 6 CYL • AUTOMATIC
MITCH196328
I tried all I could think of. The car won't start. Security light flashing.
Mar 23, 2022 at 5:20 AM
Let's try a couple things unless you have done this so, please run through this guide and tell me if none of it works:
https://www.2carpros.com/articles/how-to-reset-a-security-system
If it doesn't then we may have an issue causing the theft system to be on. So that means we need to scan for codes and find out if there are issues.
This vehicle is basically a Dodge Caravan so we should have some codes that will point us to a body issue which means they will be B codes.
So, let's start with this info and go from there.
Thanks
Mar 24, 2022 at 2:45 AM
