I had a check engine light while driving.The scan shows code P0410-Secondary air injection: (fault function chain)Air flow is too low.
I checked all the relays,fuses,vacuum lines.
Replaced the post catalytic o2 sensor.
Erased the code and returned on driving 2 miles.
I notice smell of gasoline on and off in the car and rough idle as well.
Planning on changing the canister purge valve.
Sir, waiting for your expert comments.
Apr 11, 2021 at 5:22 AM
