Secondary Air Injection Solenoid 191-906-283-A vacuum line routing
1999 VOLKSWAGEN BEETLE
177,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
XXXDRAGON
The problem i'm having is a vacuum line from the secondary air injection solenoid is not connected anywhere. there are 2 vacuum lines, and one electrical (the electrical is fine). one vacuum line runs from the check valve on the brake booster vacuum line hose pipe (that runs from the air intake to the brake booster with the valve in the middle). the second one is a green one (in the picture) is connected to the secondary air injection solenoid also, and is not hooked up anywhere. i need to know where it is supposed to be hooked up to please, and thanks. i have looked everywhere, and even looked for schematics for it.
Aug 19, 2020 at 5:51 PM
Good morning,
Can you please check the diagram I sent or attached to this post and tell me the number of the line you are talking about?
Your picture showed only a line with no beginning or end.
Aug 19, 2020 at 9:46 PM
XXXDRAGON
Actually if you look closer you will see the green line is attached to the secondary air injection solenoid, and the reason i didn't show the other end is it isn't attached to anything which is the problem. and the other line which is also attached isn't the problem it goes down to the check valve on the brake booster vacuum line hose pipe (that runs from the air intake to the brake booster with the valve in the middle). so with your schematic it is showing that it is the number 2 (the line) that runs from the number 4 (the secondary air injection solenoid) , and then to the number 1 (whatever it is, which is what i need to know since i now have your schematic but nothing telling what they are). the people who had this before me took all of the information stickers out from under the hood (why i don't have a clue). so if you can tell me what number 1 is that is where i need to hook my other end of the line to. thanks.
Aug 19, 2020 at 10:10 PM
I am sorry I am taking so long. I have been looking for a vacuum diagram for this system and having a tough time getting information.
I just want you to know I am still looking.
Aug 20, 2020 at 9:27 PM
XXXDRAGON
no need to apologize. if it was easy i might have found it. lol Do you have the other part that goes with the picture that you posted? it looks pretty much like what i have, but i need to know what some of the parts numbered are. thanks for your help.
Aug 20, 2020 at 9:37 PM
I will find that as well in my investigation.
Aug 20, 2020 at 9:40 PM
XXXDRAGON
thank you, and have a great day.
Aug 20, 2020 at 9:41 PM
You are welcome.
You as well.
Aug 20, 2020 at 9:44 PM
